This message displays the contents of a transmitted or received MKPDU's Distributed SAK Parameter Set Body Each MKA PDUs (MKPDU) contains a sequence of "parameter sets": Basic, Live Peer List, Potential Peer List, SAK Use, Distributed SAK. The Distributed SAK Parameter Set Body is only sent by the Key Server immediately after it generates a new SAK. Key Number: Assigned by Key Server (sequentially, beginning with 1) CipherSuite: optional 8-octet cipher suite reference number (if not populated, cipher suite defaults to GCM-AES-128) Wrapped SAK: AES Key Wrap of Secure Association Key Further details on MKA parameter sets and parameters can be found in Clause 11.11 EAPOL-MKA of IEEE Std 802.1X-2010.
No action required - Informational message only.
Debug-Verbose
%direction% MKPDU on port %slotPort% [Distributed SAK] Key Number:%keyNum% CipherSuite:%csId% Wrapped SAK:%aesWrap%
| Name | Type |
| slotPort | SlotPort |
| direction | String |
| keyNum | uInt |
| csId | HexNosByteArray |
| aesWrap | HexNosByteArray |
